Welcome to the Land Rover and Range Rover Forums, an online Land Rover forum community where you can join thousands of other owners
from around the world discussing all things related to Land Rovers. To gain full access to Land Rover World you must register for a free account. As a registered member you will be able to:
If you have any problems with the registration process or your account login, please contact contact support. |
Thread Tools |
#1 |
Roverito
![]() Join Date: Mar 2008
Overdrive or no overdrive?
Hi all,
I have a 1970 Serie IIA and I am in the process of getting some work done. The restoration place strongly suggested I consider adding a Rovers North transfer case for $1,800 (parts and labor); their justification is that even over short distances it helps the engine by allowing it not to run as hot. I drive the rover every weekend, but I do not drive it over long distances often at all. I have to be honest, I am not familiar with the concept of an overdrive and therefore don't know if it is a good investment. I am already spending a significant amount, no where near a full restoration but still a pretty big dent in my pocketbook, and I am not sure whether I should go for it. Comments, ideas?? Thanks, Eddi |
| Sponsored Links |
#2 |
RoVerified
![]() Join Date: Oct 2007
Re: overdrive
Hi eddi.
An overdrive is a good idea for long journeys! IMHO i would purchase a fairey or toro overdrive both are easy to fit by the average land rover enthusiast! also for cooling purposes i would fit a kenlowe type electric fan in front of the radiator and keep the existing viscous fan, this will give you all the cooling a series engine should ever need. It may also be prudent to have the existing radiator re cored and the engine water jacket flushed out. dan
__________________
You know when your series 3 is running fine, when it rattles, whines,clunks,knocks, smokes and leaks. :
#3 |
Roverito
Hi Dan and thanks for the reply.
I am having the radiator re cored, so that's a step in the right direction. I simply do not take the Rover on long trips often; the most I would ever do is drive about 50 miles one way to go see my brother, and that's not very often. I don't see enough benefits to warrant an $1,800 expenditure. Eddi |
#4 |
Roverito
![]() Join Date: Aug 2008
overdrive
Definately invest in an overdrive if you plan on taking the highway anywhere. I bought my series with an overdrive and move well at 60-65 mph. But my top speed not using overdrive is only 45 mph
#5 |
Rover Guru
![]() Join Date: Feb 2006
The Rovers North transfer case is not an overdrive, it's called a "high ratio transfer case". It's raises the high range (only) gearing by about 31% and is always "engaged". An overdrive, by comparison, is selective and raises all gears by about 27%, effectively giving you 16 fwd and 4 reverse gears. The transfer case conversion is generally considered to be more rugged than an overdrive.
I've been driving Series Rovers for over 30 years and never had a problem with overheating without an overdrive, even when driving 60+ on the highway edit to fix typo in "ratio".
__________________
Tom Rowe Four wheel drive allows you to get stuck in places even more inaccessible. 62 88 reg 67 NADA x2 74 Air Portable - The Antichrist (tag 6A666) 95 D1 - R380 95 D90 - R380 97 D1 - ZF Last edited by antichrist : 01-12-2010 at 05:24 AM. |
#6 |
Roverito
![]() Join Date: Jan 2010
Ya overdrive is really good for long travelling like i use it i travel a lot and travelling is my passion being a photograper by profession i need to travel a lot its not for people who dont drive much
__________________
Jeep LED Tail Lights |
| Sponsored Links |
| Thread Tools | |
