Welcome to the Land Rover and Range Rover Forums, an online Land Rover forum community where you can join thousands of other owners
from around the world discussing all things related to Land Rovers. To gain full access to Land Rover World you must register for a free account. As a registered member you will be able to:
If you have any problems with the registration process or your account login, please contact contact support. |
Thread Tools |
#1 |
RoVerified
![]() Join Date: Jun 2008
D2 Power
So simple question which i'm sure will get lots of heat.
is there anything I can do to my 2003 D2 to make more power? NOW I know the obvious forced induction, high flow cats & exhaust etc etc. thats not what I mean, more along the lines of little tricks maybe intake (usually doesnt make a bit of difference) software/chip etc etc I am just curious? and yes my cars is running perfectly, all up to date. |
| Sponsored Links |
#2 |
![]() Join Date: Jun 2004
Re-Chipping the ECU will make a big difference.
__________________
Joey Cincinnati OH http://www.customroveraccessories.com 97 Disco 10 Mini MCCSm http://www.usarovers.com/ (call for Rover parts ask for Nathan 502-222-5859) Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm EAS fault http://www.rswsolutions.com When working with GEMS vehicles. Never try to locate a misfire by pulling plug leads off - pull the injector connector instead. Otherwise you can blow up the ECU. Secondly never swap ECUs between vehicles to test them, because both vehicles and ECUs may stop working, and you'll have to have them all reset by a franchised LR dealer (ouch!). To download the RAVE manual, follow this link http://www.landroverresource.com/ |
#3 |
Rover Guru
![]() Join Date: Aug 2004
Go to a 4.6 engine with a RPI Tornado chip plus a RP4 cam roller timing chain and gears. Add a cold air intake then let it breathe all the way back to the tailpipe. This first with port matching those ugly stock head ports to intake and exhaust plus porting the cast iron exhaust unless you can get headers to pass smog. They bring a red flag in my area, stock iron ported flow rather good plus a good design to start with. All this for better flow or else your just wasting your time feeding it if it can't get rid of the exhaust.
Add the 4.6 MASS to the 4.6 engine vs the 3.9 on the 4.6 engine. High flow cats vs those Rover (crap corks they call cats) then add a Borla cat back will also wakes 'em up without any low end loss from any stock specs just all positive gains. A 5 speed will also make for more performance and fun to drive plus not robbing HP. My 4.6 runs like it's a V12 now after adding a couple of home made machined items plus changing out to newer design 4 hole disc injectors. This again made a big performance gain like the first one from a 3.9 to a 4.6 engine swap. My mistake ending up being super clean on smog tests I should of gone with a bigger cam readings of 11 of 100 and 10 of 180 PPM HC smog test results. Granted retuned back for power after the smog test but 20 minutes is well worth the rewards. I had to LMAO, the other day about same question was asked and a Rover service tech of 30 years said nothing can be done to increase power or performance. Old 95 D1 here spanks LR3's with their 295 HP CHIT! I'm the one that LMAO plus it pulls from 400 rpms in 2nd if I have any forward movement at all from a stop sign. Yes they will wake up and torque is the answer plus let it breathe and fuel properly. Last edited by beemer : 02-04-2010 at 08:25 PM. |
#4 |
Rover Guru
![]() Join Date: Jun 2009
WHy do you need more power, on or off road, while towing and how much more are you looking for? Is you gas mileage bad, if so what is it and what have you done to try and improve it.
Yes, you can send the ECU in and have it rechipped, $500 and lower gas mile will get you more power. You can always go to gears, 4:11's will wake up your truck, they will drop your power and torques curve down quite a bit and you will fly with stock size tires.
__________________
Mike I am a retired service manager of 30 years, currently driving a 99 D2 with the following mods. Custom made front and rear bumpers, Warn 9500 HSI with 3/8th's rope, sliders, QT diff. guards, electronic CDL, 4:11 gears, rear Detroit with HD axles, Front T.T., HID head light conversions and 3 extra bumper mounted HIDs. To download the RAVE manual, follow this link http://www.landroverresource.com/ Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm |
#5 |
RoVerified
I'll respond to each
Joey - Thanks and helpful as always ; better or worse milage and when company for the reflash? Beemer - I am a car guy who does LOTS of custome stuff own a 525hp 2006 M3, a 1972 240Z with almost 300hp, and are extrmely capable of doing my own work. I saw your comment the other day and are suprised that you still are talking about Disco Mike there is a lot to be said for leaving car stock most if not all upgrades have some downside. SECONDLY they are turcks and you are talking about "spanking" Lr3's and how your laughing WELL try driving an LR3 vs your modded D1 and you'll understand why they are actually laughing at you! Additionally I am not lloking to race my D2 with other SUV's thats like the idiots racing their Honda Civics with their beer can muffler and K&N air filter. ALL that work you did and I can guarantee that current SUV's that qualify as fast would TRASH your hot rod D1. Lastly you should understand that your post (IMO) make you look like an A$$. DISCO MIKE - The D2 is my daily driver and I am looking to see if there is a way with minimal sacrifice to make it a bit more lively. They are pretty underpowered and sluggish even in good shape, not hatefully so but they are, SO I am looking for a little more pep. I do however appreciate your position that most mods are not worth it unless they are serving a specific purpose. |
#6 |
Rover Guru
Yup laughing so hard one of my LR3 friends wanted a direct swap for my D1. I'm down to two LR3 owners, the third was rolled on the steet and totalled. I drove two of them, they sure added some pork to them, not impressed might as well go for 3 tons empty weight.
When looking at a D1 years ago I about barfed and switched brands after driving a couple automatics. The reason I came back was after driving a D1 5 speed with a 4.9 that wasn't stock. This also a purpose built vehicle like mine for street use only. LR3 owners laughing, well pissed was the word from a few plus i'm under $19K the total price of this vehicle project. No used value so I built it for my use and have fun, when done i'll part it out but keep the engine. One of your high standards on engines and has to ask how to increase power sounds rather gay in my book. Enjoy your Rover stock like Mike stated. Being slow you can't snap axles and twist out those rubber POS U joints. My guttless motor seems to do this until a real steel U joint was added plus retrained the left foot to not snap axles. Purpose built like those that add 350 Chebbies to them looking for fun. Last edited by beemer : 02-05-2010 at 10:26 PM. |
#7 |
Rover Guru
You could though, if you like Rovers, buy one of the new special addition 2010 RR that has 510 horse power right out of the box for only $89,000.
__________________
#8 | |
Rover Guru
Quote:
I would rather stuff the 928 Porsche engine I have in storage and strip the weight off the Rover, convert to two wheel drive if I wanted to have some real street fun. My friend in Va. snagged a cherry 95 D1 with a transfer box failure for only $1,500 so we both have more spare parts to swap each other. |
#9 |
RoVerified
Joey - who so you recommend for the flash and did you notice better or worse milage?
#10 |
Rover Guru
![]() Join Date: Mar 2009
Huh?
__________________
96 RR 4.0se (SOLD dammit) 97 D1 SE7 125k easy link to simple Rave cd:download the large 590mb file http://www.landroverresource.com/ |
| Sponsored Links |
| Thread Tools | |
