Welcome to the Land Rover and Range Rover Forums, an online Land Rover forum community where you can join thousands of other owners
from around the world discussing all things related to Land Rovers. To gain full access to Land Rover World you must register for a free account. As a registered member you will be able to:
If you have any problems with the registration process or your account login, please contact contact support. |
Thread Tools |
#1 |
Landy Man
![]() Join Date: Jan 2010
Washer Fluid Jets
I push the button for my washer fluid to come out on to my windshield and I get nothing, There is plenty of fluid in my tank can anyone help me out? Could it be the fuse for the washer jet? And do you know the number of that fuse?
| Sponsored Links |
#2 |
Rover Guru
![]() Join Date: Feb 2007
i live right near the ocean... the little ends get clogged alot... u can pin them out with a tiny pin or file
#3 |
Rover Guru
![]() Join Date: Dec 2009
Frozen Fluid?
__________________
www.gnvehicleprotection.co.uk Sump Guards, Rock Sliders, Exhaust Bungs, Jack Adaptors for the Discovery 3 / LR3 Check out the new club: www.disco3club.co.uk |
#4 |
Landy Man
![]() Join Date: Dec 2006
Long shot, but lift the hood and make sure the hose is connected to the jet.
#5 |
Rover Guru
![]() Join Date: Dec 2008
Do you hear the pump activate when you outside the vehicle?
__________________
__________________________________________________ 2005 LR3 SE7, 285/60R18 Nitto Terra Grapplers, Full OE Brush Bar; Expedition Roof Rack, GN Vehicle Protection Ladder, rear lamp guard, Johnson Rods lift, Q Industries On-board compressor (in extra battery box), LR driving lights (work independently) 2006 Honda Odyssey (I know, I know...) 1965 Mustang Coupe (warmed-over 289) 2001 Range Rover (Sold) |
#6 |
Landy Man
No I don't hear the pump trying to spray at all that is why I thought it could be a fuse
#7 |
Rover Guru
![]() Join Date: Mar 2009
Try to check a fuse,I don't remember which one at this moment ,but i can check.It is a common problem on British forum when temperatures plummet,it is a 10 amps fuse ,but when replacing ,use a 15 instead to prevent future failures,this is a fix that LR does when it happens anyway.Cheers
#8 |
Landy Man
Thorgal, thanks I will check that fuse out, but if anyone knows the exact number of the fuse I would love the help ha ha
#9 |
RoVerified
![]() Join Date: Feb 2010
Location #11 - 10amp. Glove box fuse schematics will confirm location.
#10 |
Landy Man
Thanks BlackForestham!!!
| Sponsored Links |
| Thread Tools | |
