Welcome to the Land Rover and Range Rover Forums, an online Land Rover forum community where you can join thousands of other owners
from around the world discussing all things related to Land Rovers. To gain full access to Land Rover World you must register for a free account. As a registered member you will be able to:
If you have any problems with the registration process or your account login, please contact contact support. |
Thread Tools |
#1 |
Roverito
![]() Join Date: Feb 2010
Disco guru's HELP!!!! 3 Amigo help
hey guys im having the 3 amigo problems on my 04 disco and ive searched and searched and tried everything and i cant get them away!!!ive tried the following:
checked voltage at slabs ecu for each wss shuttle valve repair kit used modulator another slabs unit from roverlandparts.com flushed brakes Thier not staying on all the time but keep comming on and its throwing codes for: modulator, module and short at one of the sensors! any help is awesome guys!!!! |
| Sponsored Links |
#2 |
![]() Join Date: Jun 2004
Have you put your Rover on the Testbook computer to read what the issue is?
__________________
Joey Cincinnati OH http://www.customroveraccessories.com 97 Disco 10 Mini MCCSm http://www.usarovers.com/ (call for Rover parts ask for Nathan 502-222-5859) Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm EAS fault http://www.rswsolutions.com When working with GEMS vehicles. Never try to locate a misfire by pulling plug leads off - pull the injector connector instead. Otherwise you can blow up the ECU. Secondly never swap ECUs between vehicles to test them, because both vehicles and ECUs may stop working, and you'll have to have them all reset by a franchised LR dealer (ouch!). To download the RAVE manual, follow this link http://www.landroverresource.com/ |
#3 |
Roverito
i took it to a euro shop to have it scanned and there was 3 codes, i dont have the exact descriptions but they were: abs modulator, abs pump, and wss short
#4 |
Roverito
edit: 3 codes from shop
pump failure 1 pump failure 2 shuttle valve switch |
#5 |
Roverito
just got done putting some brake queit on the front brakes and rebleeding the system, still on. However i took it out in the snow and slammed the brakes and no abs pulsation at the pedel at all, would the abs not activate in the snow?
#6 |
If the ABS is not working correctly it will default to non-ABS.
http://forums.landroverworld.org/showthread.php?t=17059
__________________
#7 |
Roverito
Hi Im new here and trying to learn about my Discovery II ...
What is the three amigos? are they indicators? ABS , SERV ENG, TC, \@ where the @ is a truck going down a hill... these are the indicator lights im getting on my instrument display panel.. or is three amigos something else... is that what you mean by three amigos? |
#8 |
Three amigo's are ABS/TC/HDC (Hill Decent Control) i.e truck going down hill.
Serv Eng is engine codes and you should have them read with an OBDII scanner.
__________________
#9 |
Rover Guru
![]() Join Date: Jun 2009
Send me your tele number, I'll be glad to help you.
__________________
Mike I am a retired service manager of 30 years, currently driving a 99 D2 with the following mods. Custom made front and rear bumpers, Warn 9500 HSI with 3/8th's rope, sliders, QT diff. guards, electronic CDL, 4:11 gears, rear Detroit with HD axles, Front T.T., HID head light conversions and 3 extra bumper mounted HIDs. To download the RAVE manual, follow this link http://www.landroverresource.com/ Rover Radio issues or IPOD Adapters http://home.valornet.com/splacket/index.htm |
| Sponsored Links |
| Thread Tools | |
